V7s Plus Water Tank Not Dripping
ILIFE V7 Plus: How to Fix it Water Tank Issue
For wet cleaning, V7s plus uses i-dropping technology in which it sprinkles the floor. To ensure thorough wet cleaning, water tank must be inserted properly. There are four simple steps to insert water tank. There are four simple steps to insert water tank.There are four simple steps to insert water tank.
 1. Filling the water tank: Open the water injection cap and fill the tank with plain water.
 2. Checking for water dripping: Make sure the water is dripping by checking from bottom of the tank.
 3. Inserting the water tank: Insert the water tank by pressing gently to ensure that it fits properly.
 4. Closing the lid: Close the lid and make sure the mopping cloth is attached at the base. V7s plus is ready for mopping function.
